My Star L406D - Portugal
Re: My Star L406D - Portugal
Messagepar danuel » 01 PMvJeu, 11 Sep 2014 12:06:58 +000006Jeudi 2009 041240
Hello Merco Friends!
I hope you back from festivaltours :) :twisted: :twisted:
Finally, I buy the gearbox 5 velocity. Its from a MB 190D. :roll: :mrgreen:
The number is R 124 261 03 01
I think it is good for my van! :roll:
I check the engine starter, and it is the same side. :mrgreen:
Friends tipierre, ram Luciano, what do you think about that gearbox?
It is good with no modifications on my Merciana ? :O :oops:
Best Regards!! :)
Mercedes L406DG - http://youtu.be/fyrsEUCbUfI
Donate to Merciana with Bitcoin.
BTC Address: 13Qs5NQQNBGn4eQBnVXVLvN6kqSzm2rcsb
danuel
Inscrit le: 01 PMvMer, 29 Sep 2010 12:42:14 +000042Mercredi 2009 041240
Messagepar Luciano » 01 PMvMar, 30 Sep 2014 22:27:55 +000027Mardi 2009 041040
Wait don't you have a small iron plate on the gear box with a number on it ?
I can't tell anything with the number you gave...
If you can check how many turns the output shaft does while you are giving 10 turns on the input shaft (on the 5th gear of course). That will tell us if it is a long or a short gear box. You may need a short... Anyway there will have modifications to do, but not so much if you get the right gear box :)
Maison ambulente
Légende personnelle
Emily Dickinson
Luciano
Messagepar -gaston- » 01 PMvMar, 30 Sep 2014 22:55:00 +000055Mardi 2009 041040
I'm quite sure that you cannot fits this box in your 406D without important modifications.
the clutch of the 406D will not fit with the 190 clutch shaft.
Messagepar danuel » 01 AMvMer, 01 Oct 2014 10:41:55 +000041Mercredi 2009 041040
Hello Friends!
Well I search to number. And i found that long number.
124 260 63 01
717 412 0 6007436 (i think this is two numbers in same line, that number is valid on epcMB ;) ).
Thankss :)
danuel
